Pulling injectors
Old 05-03-2014 | 01:14 AM
Default Pulling injectors
I will be removing the fuel injectors to have them cleaned on a 500efi. Any advice would be helpfull. I think I'm going to have to pull the intake. Where can I get the Orings for it other than merc. What style injectors are these? Can I reuse injector Orings?
Thanks. Any input would be great!
kevinb230 is offline
Old 05-03-2014 | 01:49 AM
If you get them serviced at a reputable shop you will get them back with new filter screens and all seals. Make sure you lubricate the o-rings before you put them back in.
Here are a couple I've had good experience with.
Marren Fuel Injection
RC Fuel Injection
Griswald is offline
Old 05-03-2014 | 02:52 AM
call http://www.dpii.com/ ask for jim,he has everything and can also do the cleaning,flow them and new screnes and has the orings..
FIXX is offline
Old 05-03-2014 | 05:44 AM
We use Marren Fuel Injection. www.injector.com. Tim isn't just some guy with an injector cleaning machine. He thoroughly cleans and checks each injector for flow and operation, installs new o rings ands screens. Fuel injection is not a side business for him, it is all he does. He does complete system design for just about anything and is a racer himself (IMSA Continental Tire Series).
sbracing is offline
Old 05-03-2014 | 08:30 AM
Mbam's Avatar
Offshoreonly Advertiser
We always send them back with new o rings & screens
http://www.bammarine.com/Ourstuff/Fu...orService.aspx
Mbam is offline
Old 05-03-2014 | 11:15 AM
BUP
Also some added info and we offer fuel injector services as well. Read post 10 from the link below. Also have to add about our service that most top feed injectors are 25 to 30 dollars per injector. The range can be 25 to 35 dollars per injector for side feed injectors.-
IMO 4 important things that nobody looks at beforehand on choosing a fuel injector service is, does that service test flow a fuel injector with a test fluid that matches the specific gravity of current fuel blends - this provides more real world results to compare, next do they use a quality machine, next does this service back flush an injector after it has been cleaned with a back flush system, next is before you even pull your injectors, it is wise to number your injectors as to which cylinder you pulled them out from the fuel rail. A really bad injector can possible pinpoint a problem cylinder. I do not think I have ever seen a fuel injector service tell you to mark your injectors beforehand.
http://www.offshoreonly.com/forums/d...-cleaning.html
BUP is offline
Old 05-04-2014 | 03:26 PM
Should I replace the intake Orings? If so where is a good place to get them?
Old 05-04-2014 | 03:55 PM
Napa has them, but I don't recall the P/N.
Cole2534 is offline
Old 05-05-2014 | 03:13 PM
Well I dropped them off today, they are going clean, flow and replace seals and filters. $18 per injector and will be done Wednesday. Now hopefully I can find the P/N for the intake o-ring.
Old 05-05-2014 | 04:04 PM
Fel pro part number ES 70599.. any of your local auto parts stores will have them if they carry fel pro,,napa preferably..
FIXX is offline
