prop shaft height
The Ideal height will Vary by boat, Sometimes even boats from the same mold depending on what it is going to be used for. Racing/Cruising etc. If what you're going for is top speed then higher is better "To a Certain Extent" once you are high enough to lose leverage, Then you lose Trim-ability. You can get some back using props with more blade area, After that you need to start going back down
If you can try some shorty's that would be good, Actually you'd rather get high (Prop shaft hight
) by using shorty's. A Re-rig to raise standard length drives moves everything up. Can be done, I don't recommend that route for testing. A Re-rig of that type would cost as much as shorty's.
