Dire need of an accessory drive pulley for weiand 177 >
Old 05-07-2014 | 03:07 PM
Default Dire need of an accessory drive pulley for weiand 177
Looking for a 2 or 3v accessory drive pulley that works with the weiand 177 crank pulley for a 454.
I just found that mine was not the correct pulley and basically concerned that it's gonna come unglued at 5000 rpm.
So I called holley to order it and of course it's no longer available. So here I am with a dead boat without this one pulley!! Ugh
Any ideas? Thanks guys
Dave
Labattsman is offline
Old 05-07-2014 | 04:02 PM
try the blower shop, I think they have them
J. Hordubay is offline
Old 05-07-2014 | 04:05 PM
I did try them and they didn't have anything :-(
Old 05-07-2014 | 08:19 PM
Mbam's Avatar
Offshoreonly Advertiser
I have a bunch of that stuff but i am not sure what exactly you need, Can you post a photo?
Mbam is offline
Old 05-07-2014 | 08:38 PM
Basically I need a 2v minimum crank pulley for big block chevy with short water pump that works with the weiand 177 crank pulley. One that aligns the crank pulley assembly correctly. I called summit to see if the one in there catalog would work "weiand 7036 pulley" and they were not sure if it would fit or not. I called holley to ask about it and the Reply I got was " that will not work and the one that is specific for that assembly has been discontinued. Ugh!!!
I'd love to post pictures of the blower drive pulley that I have pictures of with measurements but I have no idea how to do it on this forum with my cell phone :-(
Thanks for all the help guys
Dave
Old 05-08-2014 | 05:56 AM
Mbam's Avatar
I really don't know what the 177 pulley looks like.
See if you can find someone to help you post a pic. Try and include the pilot on the back of the pulley.
Mbam is offline
Old 05-08-2014 | 01:08 PM
It would be lower crank pulley for a 525SC. It is one pulley with 3 slots for V belts and a 10 rib on the outer side.
Griff is offline
Old 05-08-2014 | 01:32 PM
Mbam's Avatar
This is what i found up in the attic
Attached Thumbnails Dire need of an accessory drive pulley for weiand 177-sam_1353.jpg
Mbam is offline
Old 05-08-2014 | 03:00 PM
It sure does Marc, does the blower pulley separate from the v belt pulley? Also is it a 10 rib blower pulley?
Thanks for all your help :-)
Old 05-08-2014 | 03:21 PM
Mbam's Avatar
This is 1 piece. It's 6" OD, yes 10 rib
Can you use it?
Mbam is offline
