Go Back  Offshoreonly.com > Technical > Electronics
1/0 Battery Cables >
1/0 Battery Cables
1/0 Battery Cables
Old 05-11-2014 | 11:44 AM
inspector747's Avatar
Default 1/0 Battery Cables
I have 2 Blue top Optima batteries that are in parallel, My current setup has a single 4 gauge wire running between both batt's, I just purchased 4 battery terminals that will allow me to run dual 1/0 wires between the batt's
Will this damage the batteries? is there a benefit from doing this?
Bryan
inspector747 is offline
Old 05-11-2014 | 12:11 PM
It won't hurt anything, just allows for a very large amp flow.
kevinb230 is offline
Old 05-11-2014 | 01:28 PM
Won't hurt a thing.
Couginitnordic is offline
Old 05-11-2014 | 01:57 PM
Bigger is better 99% of the time when dealing with batteries.
beaver 3 is offline
Old 05-11-2014 | 02:12 PM
Current flow is like a hose.....the bigger the more flow. Just make sure to have the same sized grounds also.
Jonesyfxr is offline
Old 05-11-2014 | 03:37 PM
So I have 2 1/0 (Pos and Neg) in parallel and 1 ea going to the starter and block coming from the battery switch
Old 05-11-2014 | 04:15 PM
How are you hoking up the wire from the alternator? Those cables look great!!
Old 05-11-2014 | 04:22 PM
I already have 1 cable each coming from the block and starter going to the battery switch, now I need to make a wire to go from the alternator to the batteries..... Thanks BTW
Old 05-11-2014 | 05:32 PM
SB
Why do you need two 1/0 cables hooking one batt to the other ?
SB is offline
Old 05-11-2014 | 06:05 PM
Check at the starter, you may already have an alt wire there. I'd just run a new wire from alt to starter if that's the case.....unless you have a bat switch.
