500 efi need help wont run >
Old 05-11-2014 | 05:13 PM
Default 500 efi need help wont run
hi guys i pulled off the winter cover and tried starting the engines its a 2000 with 500 efi's one motor only will fire on one bank nothing on other side and other motor has 2 psi fuel pressure i replaced both fuel pumps last year so thinking its a regalator issue on the one engine but the other will only kick on one side thinking there may be a bad ground issue on the injectors ? i am going to order a scanner this week since kinda lost with out it any help would be great thanks off shore only
mikesystem01 is offline
Old 05-11-2014 | 07:13 PM
Grounds are a good place to start, especially the one/ones that ground the ECM itself.
TooLateVTEC is offline
Old 05-11-2014 | 07:36 PM
Ya I am hoping that's all it is I need to look in the wiring diagrams see if there different sides for injectors
Old 05-11-2014 | 09:03 PM
Check your batteries! I had issue last spring, radio came on, though I didn't crank it up. Motor wouldn't do anything, ended up being dead cell. It was weird b/c it had a lil juice to run radio and other accessories I tried as I was trouble shooting.
Cold can kill batteries!! Good luck ,
nailit is offline
Old 05-11-2014 | 10:33 PM
thanks guys i am still digin in to it
Old 05-12-2014 | 08:04 PM
Starting to think I have a ground problem on the one side of injectors
