Battery Selector Switch??
OK. Guys, I have a stupid question, so bear with me.
Recently had trouble starting my starboard engine, I have always ran both of the selector switches on the ,,Both Battery,, setting for years, it always worked perfectly,
so couple weeks ago my starboard engine would crank , but not fire, so after looking and trying several other things first, connections, etc., I turned that engine Battery Selector switch to the #1 Battery setting, she fired immediately , A couple days later I tried the same thing again, and again I had to turn the selector to #1, or #2 battery setting to get her to fire, it will fire on either #1 or #2 battery setting, what am I missing here, why will it crank just fine on the ,,Both Battery ,, setting ,but not fire.
If the selector switch goes bad, will it still crank the starter but kill the ignition.
Are there any electrical wiring experts out there that know how the battery selector switch wires into the ignition, apparently it can let the engine crank over, but kill the ignition so it won't fire
The ignition is wired from the motor,.... Well beyond the battery selector,...
Only the batteries are controlled by the battery switch,....
Get out yer test light, 'n figure out what's happenin',....
