performance gain??? >
performance gain???
performance gain???
Old 05-15-2014 | 03:54 PM
Default performance gain???
I have a 94 GEN V 7.4L 330, is there any real performance gain putting on EMI thunder manifolds and tube style risers?
bigbird241 is offline
Old 05-15-2014 | 04:03 PM
vintage chromoly's Avatar
In a word, no.
It's all about the total combination of engine componentry. Adding one item alone doesn't make much difference and the emi thunders are only a small step up from a stock manifold.
vintage chromoly is offline
Old 05-15-2014 | 04:06 PM
Originally Posted by vintage chromoly
In a word, no.
I'm eventually doing rectangle heads/intake, and cam. I dont want to get too crazy with the stock bottom end, maybe 375-400hp is my target. I can get this exhaust for cheap, I figured a good step forward in direction.
Old 05-15-2014 | 08:30 PM
If the exhaust has the dry joint between the manifold and riser, then it is a good upgrade just for the sake of longevity. The stock 496 manifolds also have this, and flow a little better than the regular stock 454 manifolds and risers. You could probably find a set of these as take offs in the $500 range if you look long enough.
Budman II is offline
Old 05-16-2014 | 01:30 AM
You will not gain any performance.
Griff is offline
Old 05-16-2014 | 06:53 AM
VoodooRob's Avatar
I was in your shoes a couple years back. 95 carbd 454, not a mag engine. I bolted on Dana exhaust, air gap intake, Holley carb and MSD ignition. Ran much better, I'm saying it was from the fresh carb more than anything. I then did rectangular heads and performance took a step backwards until I pulled the engine and did the cam. That's when it all came together. So +1 for doing an entire package, just have the right expectation when throwing a single performance part on.
VoodooRob is offline
Old 05-16-2014 | 07:04 AM
well I went ahead and bought the exhaust, they are actually IMCO Powerflows, NOT EMI like I thought, but I got them for $500 shipped to my door.
Old 05-16-2014 | 07:58 AM
Sounds like a good deal. Have they been pressure tested? Fresh water or salt?
Old 05-16-2014 | 08:27 AM
VoodooRob's Avatar
Not bad price as long as fresh water or low,low hour salt.
Old 05-16-2014 | 08:29 AM
If anything it should sound a little better.
Black Baja is offline
