what heads 308 darts 290 or 305 afr heads >
Old 05-16-2014 | 05:49 PM
Default what heads 308 darts 290 or 305 afr heads
My engine is 10 to 1 454 stroked to 496 cam is a flat tappet 244 254 @.50 570 575 lift need intake carb head recommendations this is a budget build or I would go roller but thought spending money on the heads would b worth it
rotax406 is offline
Old 05-16-2014 | 07:03 PM
What exhaust?
motor is offline
Old 05-16-2014 | 07:19 PM
Pick a targeted HP from 350-600 HP and/or a budget from $10-40k per engine and the pro's and you will give good feedback.
BenPerfected is offline
Old 05-16-2014 | 07:53 PM
at 10 to 40k per motor, a roller cam is not an issue. i think his budget is more like 2-3k.
dereknkathy is offline
Old 05-16-2014 | 08:35 PM
I would be more specific with your goals. Since it is a flat tappet cam, I would not build around those cam specs, for two reasons. Flat tappet cam/lifter kits are cheap, and obviously that might not be the cam to suit your goals. A cam works hand and hand with things like cylinder head design, static compression ratio, exhaust, etc.
A properly spec'd cam/head/induction setup, is of much more benefit, than compromising parts working together.
As far as your head options, if 10:1 is where you want to be, I'd be looking at Aluminum heads. Brodix has some nice options, and so does AFR. What I like about the both of them, is you can get an as cast version of their head, with the CNC program run thru the chambers and bowl area. Well worth the cost imo. Get with Bob Madera on the AFR heads, or Eddie Young on the Brodix. Both are good guys and supporters of oso, and will not only offer competitive pricing, but also invaluable technical help to meet your goals.
MILD THUNDER is offline
Old 05-16-2014 | 08:36 PM
Pretty sure not much or anything is going to show on the GPS for $2-3k
Old 05-16-2014 | 09:00 PM
SB
Running with a GPS always ups the budget. Amazing what even those cheap $100 handhelds end up costing you. LOL.
SB is offline
Old 05-16-2014 | 10:48 PM
At 10 to 40 k per I'd think your builder better have some pretty good advice or you should find another..quick!
buck35 is offline
Old 05-17-2014 | 01:34 AM
You need to use heads and a cam that work together. Use a roller cam. There are some edelbrock heads in the swap shop that would most likely work well for you.
With 10:1 you are going want aluminum heads.
Griff is offline
Old 05-17-2014 | 05:53 AM
http://www.blueprintengines.com/inde...cylinder-heads
JRider is offline
