Boat pulls to left
Old 05-18-2014 | 06:42 AM
Default Boat pulls to left
So I FINALLY was able to get my new Cobia in the water yesterday. When I let go of the wheel it would spin to the left then stop. It was acting like the steering was out of adjustment, almost like if you let go of a car wheel and it wants to auto center. I'm new to boats and I feel it's most likely an adjustment. This is a 260hp 350 Chevy with an Aplha drive.
Thanks in advance for any help.
Jonesyfxr is offline
Old 05-18-2014 | 07:13 AM
I don't know if you have a steg fin on the drive -- chances are that needs to be adjusted. Typically it takes a hex wrench loosen and move a little in the opposite direction it is now placed.
good luck
3poinstar
3pointstar is offline
Old 05-18-2014 | 07:31 AM
jeff32's Avatar
gimball pin?
jeff32 is offline
Old 05-18-2014 | 08:21 AM
wiggle drive back and forth and see how much play there is. but when mine was real loose it pulled right when I pulled off the gas.
dereknkathy is offline
Old 05-18-2014 | 08:23 AM
It actually feels like its in the power assist, like its in the valving. I do have a skag adjustment, BTW.
good luck
3poinstar
Ayuh,.... Try adjustin' the torque tab over the prop,...
If that don't fix it,... Try a different prop,...
Bondo is offline
Old 05-18-2014 | 11:49 AM
It is due to prop torque and is normal on single engine boats with cable steering.
Griff is offline
Old 05-18-2014 | 12:32 PM
Yep
thirdchildhood is offline
Old 05-18-2014 | 02:45 PM
good luck
3poinstar
Right now it's adjusted perfectly straight. So I need to turn it counterclockwise to counteract the pulling?
Old 05-18-2014 | 03:05 PM
You could try. I know it doesn't take much
3pointstar
