496 vs 540
Old 05-19-2014 | 11:10 AM
Default 496 vs 540
I have spoken to a lot of engine builders and a lot of them are hot on a built 496 that can make 620-650HP. I can get a 540 to make that as well. It seems you can make a very strong 496 for less money than a 540 that is making the same HP. Would a 496 be a better choice or a 540? I am going to repower my 2000 38' small step Lightning and would like to hear opinions and first hand experiences of either and both engines.
682gold is offline
Old 05-19-2014 | 11:33 AM
Rookie's Avatar
It depends on if you are starting with 454's or 502's. There should not be a difference in price they are both 4.25" stroker kits just different bore diameters. If you're buying new blocks then it is no brainer and go with 540's.
Rookie is offline
Old 05-19-2014 | 12:42 PM
There's no replacement for displacement. Never heard any boater say, "Dang, I wish my engine was smaller!" LOL!
CDShack is offline
Old 05-19-2014 | 01:07 PM
the only price differance should be in piston cost..
FIXX is offline
Old 05-19-2014 | 01:35 PM
Yeah but as referenced above, if he already has a 454(s), then financially speaking, a 496 could make a lot more sense than a 540. Obviously money not being an issue, a 540 would be optimal. Be interesting to see if he has a 454 or 502...
Borgie is offline
Old 05-19-2014 | 02:33 PM
bcfountain's Avatar
Registered User
they by far more 454 blocks than 502 blocks and the 454 is cheaper to buy at swap shops and used parts guys.i just went through this on my 10meter build.it had 454,s that were played and I had 4 other 454 blocks......it was a no brainer for me.although said.no replacement for cubic displacement.i would had rather had 502,s.but the 454,s fit my budget.
bcfountain is offline
Old 05-19-2014 | 02:48 PM
Larger bore would help to unshroud the valves and help the 540 to breathe a little better. Heads, carb, and cam need to be sized appropriately for the larger engine too.
Budman II is offline
Old 05-19-2014 | 02:49 PM
Currently I have 525SC's. 454 w/ a 177 blower. I feel I could get more for the whole thing kept together than parting in out. I would keep my (manifolds) exhaust, oil coolers, power steering pump and alternators. Sell everything else pan to carb. Put that money towards a build.
682gold is offline
Old 05-19-2014 | 03:23 PM
Rookie's Avatar
Screw stroking it and get a bigger blower. 420, 6-71
Rookie is offline
Old 05-19-2014 | 03:26 PM
Trying to get away from blower motors if I can. What, in your opinion, makes more sense to put bugger blowers on it than to sell and go with N/A motors?
682gold is offline
