Fuse or not to fuse "That is the question" >
Old 05-19-2014 | 03:40 PM
inspector747's Avatar
Default Fuse or not to fuse "That is the question"
So I am in the process of rewiring the boat, I have a Holley Blue marine fuel pump that is currently connected directly to the battery, is there any reason not to run a fuse to this? and if so what size?
Bryan
inspector747 is offline
Old 05-19-2014 | 04:57 PM
SB
Protect yourself with a fuse ! It has an electric motor. Holley should able to provide you with an Amperage chart.
SB is offline
Old 05-19-2014 | 05:33 PM
Breaker.
Cole2534 is offline
Old 05-19-2014 | 08:09 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Always fuse. Fuses aren't there to protect the device. They are there to protect the wire going to the device in case of a short, thus why you always see the 'fuse within 7" of battery'
US1 Fountain is offline
Old 05-19-2014 | 09:35 PM
Thanks everyone for confirming what I thought should be right in the first place. When I saw how they wired everything I started to question.... But now will continue with the way it should be wired
Thanks again
Old 05-20-2014 | 08:42 AM
breaker then relay for the power...
ezstriper is offline
Old 05-20-2014 | 08:44 AM
30amp relay at the minimum
Griswald is offline
Absolutely and an oil pressure switch to trigger the relay.
Black Baja is offline
