Cigarette Adventure part 4 >
Old 05-19-2014 | 06:28 PM
Default Cigarette Adventure part 4
Ditch the 8-71`s for stage 4 10-71`s
Takem em down to short blocks
35hours of combustion chamber work on the heads by High Flow Heads in Alsip Illinois (A++)
Replace bolts with head studs.
Set us a proper valve train from scratch.
Spring oilers:
IMI starters:
ICDEDPPL is offline
Old 05-19-2014 | 06:39 PM
Complete rewire
Every ignition part replaced and switch from MSD to Crane
Every piece professionally polished and top coated with DURAFORTRESS top coating to lock in the shine and protect the finish.
Eliminate cheesy K&N breathers
ICDEDPPL is offline
Old 05-19-2014 | 06:55 PM
Before and after blower intake temp sensors/gauge
Add a bunch of warning sensors and lights:
Bright as hell!
ICDEDPPL is offline
Old 05-19-2014 | 07:03 PM
cigrocket's Avatar
Nice work, looking good!
cigrocket is offline
Old 05-19-2014 | 07:06 PM
Chemically removed chroming and had tabs polished and DURAFORTRESSED
Added Anode:
Added Drive switches to rear of boat (not tab)
Dry Exhaust:
ICDEDPPL is offline
Old 05-19-2014 | 07:08 PM
eightsecmopar's Avatar
Nice job Dan,!!
I like the warning system, would be kind of hard to miss those warning lights!
So with those new blowers you should probably be around what 550 hp?? Lol.... Oh I forgot you did some porting so maybe 575hp
Looks Awesome, hopefully see you on the lake soon
eightsecmopar is offline
Old 05-19-2014 | 07:28 PM
Dynoed motor
Replace most hoses, fitting , fasteners, damper plates..etc..etc.. tons of little stuff.
Get all fancy with torsion clamps and other weird stuff.
Replace all leaky expansion bottles on transom
Paint the bottom black to camouflage all stains
Going back in hope to be in the water soon:
ICDEDPPL is offline
Old 05-19-2014 | 07:44 PM
jeff32's Avatar
wow! that's clean!
jeff32 is offline
Old 05-19-2014 | 08:40 PM
You've been busy but where's the on the water video? Looking great. Dry exhaust - should be able to hear you from miles too.
abmotorman is offline
Old 05-19-2014 | 08:46 PM
Zero Patience's Avatar
Great work, and planning.
Zero Patience is offline
