Compression Test
Should the compression test be done with engine warmed up or cold? Also merc manual says to ground the Dist ignition coil wire to the block . Is that a must?
Chris
Chris
Warm and with throttle open. Coil high tension wire grounded to block to prevent engine starting or you getting shocked. I just put a philips screwdriver in the dist end of the coil and lay it on or near a ground.
I would just disconnect power from the ignition coil.
Cold is fine, just be sure to crack the throttle blades open while doing the test. Also, if its a carbed engine, I prefer to remove all the spark plugs, and crank it over for a little. Sometimes, esp with a blower, there could be a little leftover fuel sitting in the cylinder. the little bit of liquid in there can raise the number you see on the gauge.
I have to agree with all that. It's best with engine warm but I've tested plenty of engines cold and they will usually just be about 5 psi lower across the board. Probably best to disable the coil completely to eliminate any sparks in an enclosed boat engine room and, yes, just put a screwdriver in the choke housing. And pull all the plugs so it cranks faster and since you have to take them all out anyway.
The "correct" way is to have engine warm, throttle open, ect, bla, bla,bla... I have laways done it with a cold engine even on my snowmobiles. All your looking for is that each hole has pretty much the same compression, (with in 5% of eachother is what I go by). if you have 125psi on 7 holes and 75psi in 1 hole, you have a problem.
