144 blower on stock 350 >
Old 05-23-2014 | 10:02 AM
Default 144 blower on stock 350
Hello,
Looking for some advice I have an opportunity to get my hands on 2 weiand 144 blowers for cheap. I was wondering if my stock 350 mercruisers could handle them and how much modifications I would have to make. Also is it worth it? Any input is greatly appreciated.
gleber7 is offline
Old 05-23-2014 | 11:31 AM
Originally Posted by gleber7
Hello,
Fuel injected?
abmotorman is offline
Old 05-23-2014 | 11:34 AM
no carburetor with low hours all stock
gleber7 is offline
Old 05-23-2014 | 12:14 PM
Well, the good thing is that stock 350's are relatively cheap and you have two of them if you scatter one. I believe they are set up with cast pistons and crank, so if you add boost, make sure you don't set it up lean.
Budman II is offline
Old 05-23-2014 | 03:34 PM
Are they complete with all the pulleys, brackets, intake and thermostat housing? If so, put in a A/F meter, convert the carb to boost sensing, lock out timing and don't pound anymore than 5lbs of boost. Enjoy.
Old 05-23-2014 | 03:58 PM
Yes they are complete kits
gleber7 is offline
Old 05-23-2014 | 05:37 PM
A set of knock sensors might not be a bad idea either.
Old 05-27-2014 | 03:16 PM
rvtransport's Avatar
I had a 260hp merc 350 with 144 and it lasted 1 year before burning a exhaust valve. Really woke up that little engine. Gained 8 mph. Was running 6lbs boost.
rvtransport is offline
Old 05-27-2014 | 03:39 PM
Awesome that's the same motors I have I was hoping to gain 8-10 mph I'm going to try to stick with around 5lbs of boost. What carbs did you run?
gleber7 is offline
