fountain props >
fountain props
fountain props
Old 05-23-2014 | 03:25 PM
Default fountain props
Ok I know its probably been beat to death but I am new to fountains and was looking the other day. Are all Reggies single engine boats left handed props? lol I know I should've paid more attention when I bought the thing but im so used to everything being right handed. what pitch you other 27 owners running?
Gh700xx is offline
Old 05-25-2014 | 09:11 AM
They handle better turning in
27Fountain is offline
Old 05-25-2014 | 09:25 AM
He's talking about a single engine, there is no in.
Wildman_grafix is offline
Old 05-25-2014 | 04:18 PM
exactly it drives fine and everything is hooked up exactly how it came out of the boat just not used to it I guess. I figured there would be a little more input esp on what prop everyone uses .... guess not.
Gh700xx is offline
Old 05-25-2014 | 11:44 PM
Prop info will be all over the board depending on set ups. If you have a left hand prop then i would assume you have a bravo1 outdrive and someone came across a deal on a left hand prop and adjusted it at the shifter to make it work. What is your goal with this post?
keegan is offline
Old 05-26-2014 | 12:06 AM
I think his goal is to find out what way guys with 27 fountains spin there props.
mptrimshop is offline
Old 05-26-2014 | 12:22 AM
If I'm not mistaken most single engine fountains came from factory left handed.
Crude Intentions is offline
Old 05-26-2014 | 07:47 AM
Yes left hand I had a 1998 27' with a 502 I think it ran right at 70MPH with a 23pitch Hydromotive
Old 05-26-2014 | 08:03 AM
Same as mine. The Bravo one seems to be a better prop all around for me though. Lost some on the top end, but overall driveability was better. We run pretty heavy usually, 4 of 5 people and full fuel and gear.
maineriverrunner is offline
Old 05-26-2014 | 08:26 AM
thanks guys that's exactly what I was trying to find out if most were left handed or not cause it all appeared to be factory correct and hooked up right. it didn't looked rigged up or anything so was trying to find out. now if I can get the other issue I have figured out im good lol.
Gh700xx is offline
