WPM Steering
Does anyone have the instructions for purging a dual ram add on system. It's on a 28 Donzi, twin Bravo Ones using the Mercruiser power steering pump. I replaced
all the hydraulic lines and power steering pump. It's been years since I've done one and I forget the procedure. Thanks
just start, keep full of fluid, turn slowly lock to lock and shut off, let sit for a while air will bleed out, repeat a few times till drive has no play side to side when moved by hand not running..
