Need mercruiser throttle cable bracket #41363 >
Old 05-27-2014 | 05:33 PM
Default Need mercruiser throttle cable bracket #41363
I need this bracket, has # 41363 on it. I realize the one in the pic has been cut, I need another to modify
Baja226sport is offline
Old 05-29-2014 | 07:02 AM
nobody at all?
Old 05-29-2014 | 09:34 PM
There are a couple on ebay.
Port Monster is offline
Old 05-31-2014 | 08:21 AM
I can't find any on eBay that are the same as this bracket. They are all longer.
Old 05-31-2014 | 08:45 AM
Email me - I have two here that I was going to use to modify for my new carbs - just use the end for the cable on a new stainless bracket I bought. I am going from the stock Rochester carb to an edelbrock. The stock bracket is too small for the edelbrock but I found a cheap stainless alternative. I am only going to cut the end off of the oem bracket just to use for the cable end. Or just use the shaft out of it. If mine fits your application you can have it and just order me one that doesn't fit your application. If you are in a rush and it works just come get it and we will work it out later. I am at best looking at July first to get my boat in the water.
Old 03-05-2025 | 11:51 AM
Default Doing the same
I'm doing the same kind of upgrade. And I'm looking for a bracket. For the larger bolt pattern on the carburetor any ideas would be helpful.
84Checkmate is offline
Old 03-05-2025 | 03:26 PM
One of these CP Performance - Throttle Brackets
and MerCruiser Cable To Holley Carburetor Conversion Kit - CP Performance
Griff is offline
