Suv hauled from wa to ma
Yes it will fit on a trailer. An H2 is a 3/4 truck with a square body and wide tires. Likely, if going enclosed they will want to put it in the back spot for ease of loading past the tire humps. There is a number of Car haulers that can take care of you, if an open hauler, contact a local Manheim or Adesa Auto Auction, for a few dollars for them. They can help in brokering the haul, it will take the work out of it for you and likely get you a better price anyway. (they have commercial nation wide rates)
If you want enclosed, Reliable, Passport, Intercity, etc... There is also a number of independents.
Note: If you want enclosed it is going to take longer as well...
thanks, was hoping to deal directly with the actual shipper, not a broker.
Have gone thru the broker type deal in the past, and ended up getting burned last time. They not only could not hit the delivery date they promised, but also increase the price by several hundred, and there was nothing I could do about it. Broker had been paid in full, and the contract you must sign prior would not allow for american express to contest the charges based on non delivery of promises.
It is a daily driver vehicle, slightly oversizes tires. open carrier is fine
Problem I see is that most direct shippers are local, with in a 3-4 state area in most cases. You are talking about transporting it across the country, so you will need a national carrier. They are mostly tied into the major auctions (Manheim/Adesa) or Manufacturers. Even these companies split it between rail and road.
One national company to try is Fleetcar, I see their trucks all over.
Another option is Vehicle Driveaway, they would fly a person out to the vehicle and they would drive it cross country to you. This is likely the least costly to do. I just googled that and a number of companies came up.
You do realize that is a 3000+ mile trip in a vehicle that will struggle to get 12-14 mpg.....so at 13 mpg, you will burn 230 gallons of fuel, at $3.75 a gallon you are at $862 just in fuel......add some hotels, a plane ticket the other way and some profit and you are looking at $1500 minimum plus you just added 3K miles to your vehicle.
I am guessing the transport will be WAY more than that. My suggestion is that, a suggestion. Routinely we have transporters that pick up cars from us in central MO and are delivered to Chicago Manheim. They get $600-800 for the transport. Now take 3x that mileage?
There are options out there, the question is how to get it done? Not if it is worth the total cost etc...
