500HP's - what oil are you running? >
Old 06-01-2014 | 07:02 AM
Default 500HP's - what oil are you running?
What oil are you running in your 500HP's?
mikeyj08 is offline
Old 06-01-2014 | 07:13 AM
Dean Ferry's Avatar
Veteran: Air Force
Mobil1 15-50
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 06-01-2014 | 07:41 AM
valvoline vr1 racing 40w
BIGMC69 is offline
Old 06-01-2014 | 08:45 AM
Originally Posted by Dean Ferry
Mobil1 15-50
+1
RT930turbo is offline
Old 06-01-2014 | 08:49 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Please read ! http://www.amsoil.com/shop/by-produc...50-racing-oil/
the deep is offline
Old 06-01-2014 | 09:10 AM
i ran 15w40 rotella in my 500s. my builder said they were the cleanest engines he's ever disassembled
Rbesola is offline
Old 06-01-2014 | 09:21 AM
glassdave's Avatar
Neno the mind boggler
Was told by a friend of mine and engine builder that Rotella is one of the few oils that still retains zinc. A must if you are running non roller cams and something to be aware of when choosing an oil. He has seen an increase in cam failures in recent years in a rate seemingly directly proportional to the rate at which zinc has been backed out. I run Merc 15-40 in everything or Brad Penn, though i think i heard Merc is removing zinc as well.
08 OPA High Points Champion
glassdave is offline
Old 06-01-2014 | 09:28 AM
BUP
Merc motor oil is made by Citgo and the reason for one of the motor oil's offered by merc to have the lower leverls of Zinc and phos is because of the catalyst engines, Zinc and phos coat the catalyst core over time from blow by and degrade the core. Merc came back out with another Service Bulletin switching back away from the 20 w -40 syn low zinc / phos oil. I have all the Merc SB's.
BUP is offline
Old 06-01-2014 | 09:34 AM
glassdave's Avatar
interesting, i knew it had to be an emissions reason to remove the Zinc and Phos. Its unfortunate other result is cam life issues.
Old 06-01-2014 | 09:41 AM
I have also had exceptional results with rotella, another great choice.
