vst to fuel rail???
Old 06-01-2014 | 09:38 PM
camptappakeg69's Avatar
Default vst to fuel rail???
Looking for a little help, after sending injectors out for service I marked the outflow from vst electric pump to the bottom line of the fuelrail when I took it apart. In the merc service manual it shows a pic of that as correct, then later on in the manual it shows that line as the return. In Merc #16 on page 5C-22 it shows the bottom line as the input and the top as the return, then on page 5C-154 it shows the opposite.....which is right? Has it been wrong all this time??
camptappakeg69 is offline
Old 06-01-2014 | 09:59 PM
Not sure which way is correct, but as long as there is a feed line and return line, it really shouldn't matter which is which.
Griff is offline
Old 06-02-2014 | 09:13 AM
Thanks..wasn't sure if it made a difference which side of the regulator and filter the inlet was on.
Old 06-02-2014 | 06:35 PM
top on rail to top on pump
bottom on rail to bottom on pump
tunertech is offline
Old 06-03-2014 | 06:58 AM
So it does make a difference? Not really a top and bottom on vst, out and in so guessing top of rail is inlet bottom is return?
Old 06-04-2014 | 05:29 AM
Return is cast into the VST housing, it goes to the bottom of the rail. Yes, it does matter.
Cole2534 is offline
Old 06-04-2014 | 11:53 AM
Thanks guys. Hopefully fire it up tonite and on the water this weekend sometime!
