bravo 1 noise and leak
Was out this weekend and everything was fine. Went to take off and noticed a slight noise. Stopped did a quick inspection (had drive lube), so went to power or again and noise got much worse. Sounds similar to a failed u joint. Only noticeable in forward gear. Put the boat away and came back today to notice this leak all the way around the drive. Any ideas? Will post picture very soon.
You didn't mention anything about the BOOM that occurs before the oil starts to leak from between the upper and the bell housing....I'd say a broken tooth also, along with a broken upper housing right behind the pinion bearing spanner nut
No "boom". Just Got noticeably worse at second throttle. Never noticed an oil leak until after the boat was parked overnight. Going to pull off tomorrow, but was just looking for a direction to head. Thanks for any and all help
