496 Mag ECU - Mercury 555 >
Old 06-03-2014 | 07:49 PM
Default 496 Mag ECU - Mercury 555
Have a working 496 Mag computer - $500 + ship, UPS, FedEx or USPS.
you can request pictures at [email protected] or call 760-522-0202 if you have questions. Calling hours are 8am to 10:30pm Pacific Time please. Thanks!
SDFever is offline
Old 06-09-2014 | 11:18 PM
Unit was purchased and tested for spare but not used. These are around 1,800 new. It's also a great unit if you want to re-program it for power upgrade such as Raylar, Whipple etc. I have a harness as well but not listed.
If you need fast shipping, send me message with your phone number.
This box can easily be changed to the 496 HO if you need that as well.
SDFever is offline
Old 06-11-2014 | 05:00 AM
do you have the part number ?
tazdevil is offline
Old 06-11-2014 | 09:20 AM
sorry I do not. What I'm certain of is that it is from a vintage 2004 system and it's NOT for DTS. Here are the numbers on the box - VK016ZZ1, 885557 and as stated before, the model of the box is "PCM 0308". It "used" to be one of the only models that could be sucessfully programmed by after market. That has since changed.
SDFever is offline
Old 06-11-2014 | 09:54 AM
This is the part number i was able to find. 865364T02
We've swapped many boxes around on many engines. There are only 2 part numbers for the base model from beginning to end. We've used both of them on various engines. They are interchangeable. The only problem I've found is that obviously you can not use a DTS Box on an engine that is not equipped with it or vice versa.
This box will work for you if you do not have digital thottle and shift. It is for a boat with cables for thottle and shift.
SDFever is offline
Old 06-11-2014 | 10:00 AM
SDFever is offline
Old 06-16-2014 | 10:29 PM
ttt
SDFever is offline
Old 06-21-2014 | 06:35 PM
you have a wiring harness?
CATF800 is offline
Old 06-22-2014 | 03:07 AM
Yes I do. 496 Merc Harness.
SDFever is offline
