Pneumatic Cylinder for C.M.I Muffler >
Old 06-05-2014 | 04:50 PM
Default Pneumatic Cylinder for C.M.I Muffler
Looking for one pneumatic actuator for a cmi external sound choice muffler. TIA.
bigfarmer is offline
Old 06-05-2014 | 05:18 PM
ROB FREEMAN's Avatar
show me a pic i might have one , i have something
ROB FREEMAN is offline
Old 06-05-2014 | 08:12 PM
[ATTACH=CONFIG]524338[/ATTACH]
Attached Thumbnails Pneumatic Cylinder for C.M.I Muffler-20140605_183146.jpg
Old 06-05-2014 | 08:50 PM
RMPRam's Avatar
What is the stroke? Give me the distance from the mounting hole, on the right side of your picture, to the clevis "hole" compressed (as in the picture) and the extended distance between the holes. I may have some new air cylinders.
RMPRam is offline
Old 06-05-2014 | 09:33 PM
If RMP doesn't I'm almost positive I do. I've got a ton of pneumatic cylinders, new. If I've got one that'll work you can have it.
payuppsucker is offline
Old 07-16-2014 | 07:00 PM
1.5" stroke
tip of threaded rod to back mounting hole is 6.0"
center mounting hole to center mounting hole is 6.5"
holes are .250"
Old 07-19-2014 | 11:52 AM
Is it leaking air????? They do come apart and there are O rings inside that can be replaced. Mine are the older all metal version and I have replaced O rings in a few of mine.
Griff is offline
