Permanent Fuel pressure gauges in engine compartment? >
Old 06-06-2014 | 07:06 AM
Default Permanent Fuel pressure gauges in engine compartment?
Does anyone run a permanent guage in the engine compartment or is it not needed? The application is a single 4150 carb setup. I tried to buy a guage from summit a few years back and they didnt even want to sell me one if I was going to mount it perminantly!
I have had issues with flakey/failing (gaffrig) sending units in the past on my 575sci and ended up mounting one on the throttle body, I have not had any problems but I am rethinking the wisdom on this.
Also what about liquid VS non liquid filled?
JRider is offline
Old 06-06-2014 | 07:33 AM
glassdave's Avatar
Neno the mind boggler
I put them on nearly every boat i have ever had, usually right at the carb inlet.
08 OPA High Points Champion
glassdave is offline
Old 06-06-2014 | 07:38 AM
Ive ran a summit brand liquid filled permanently mounted on a street car. The car has more cam than we can run on the water so it shakes things pretty good and it been holding up for about years. I would think it would work just as good in a boat.
beaver 3 is offline
Old 06-06-2014 | 07:45 AM
You prefer liquid or non liquid?
JRider is offline
Old 06-06-2014 | 07:48 AM
glassdave's Avatar
liquid for sure, keeps the needle a little more static.
Old 06-06-2014 | 07:56 AM
I've got them on mine. I have to replace one since part of the needle broke off, but Its nice to have when comparing to goofy sending units. I want to do something for oil pressure too since one side seems to drop lower than the other, but both run around 60 under load, but thats another story.
sleev-les is offline
Old 06-06-2014 | 07:59 AM
Default Liquid
ICDEDPPL is offline
Old 06-06-2014 | 08:17 AM
F-2 Speedy's Avatar
Im running them, liquid filled, screwed into the EFI bypass regulator
F-2 Speedy is offline
Old 06-06-2014 | 10:20 AM
Rookie's Avatar
Liquid on the engine and I'm installing some in the dash eventually.
[ATTACH=CONFIG]524360[/ATTACH]
Attached Thumbnails Permanent Fuel pressure gauges in engine compartment?-fuel-guage.jpg
Rookie is offline
Old 06-06-2014 | 11:36 AM
Rookie, if that is a summit gauge it is exactly the one I bought with the silver styled face.
JRider is offline
