Kiekhaefer 280s K-Planes / Trim Tabs with Pumps
Set of used Kiekhaefer kplane trim tabs. I purchased these and didnt end up mounting them on my boat, ended up finding a set of smaller trim tabs instead... I have a 21 footer and these were just a tad overkill.
The tabs themselves have been stripped down to the aluminum, primered with Zinc Chromate, and then painted with multiple coats of Mercury Black and then coats of clear. Comes with a set of Kiekhaefer trim pumps that were also stripped and repainted, I have the bottoms removed in the pictures to show how clean they are inside with no signs of goo, dirt, or sludge but have all bolts and gasket. Brand new mercury solenoids and wiring to the motors. Trim rams move smoothly and no binding. Trim tabs measure 14"w x 19"l x 10" h.
You will need a set of hoses, which can either be purchased from mercury parts or you can have standard SS braided hydraulic lines made. Also needs the pins for the trim rams.
Asking $900 obo.
Asking $900 obo.
picture of a set of "new" 280s planes... 2 thru-hulls and no "studs"
(not mine, just showing an example!!!)
