Spitting out grease
Old 06-09-2014 | 07:57 AM
Question Spitting out grease
one of my 6 hubs (front one) always spits out grease past the cap and all over the wheel.. any ideas why?
ICDEDPPL is offline
Old 06-09-2014 | 07:59 AM
Cuz it doesn't like swallowing....
Unlimited jd is offline
Old 06-09-2014 | 09:17 AM
In that case its getting REPLACED!
ICDEDPPL is offline
Old 06-09-2014 | 09:59 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Is it getting hotter than the others?
Sydwayz is offline
Old 06-09-2014 | 10:29 AM
obnoxus's Avatar
Charter Member #1171
What he said !!!??
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 06-09-2014 | 10:42 AM
Knot 4 Me's Avatar
Might have a brake dragging a bit.
Knot 4 Me is offline
Old 06-11-2014 | 07:44 PM
Excessive air trapped inside hub???
zz28zz is offline
Old 06-12-2014 | 01:58 AM
you need a new cap..a bead of sealer works like a champ on used caps..just under the lip were t bottoms out on the hub,then wipe off the access..i do it on all the wheel bearinf repacks i do..
FIXX is offline
Old 06-12-2014 | 06:11 AM
you have a bad hub,,as the hub gets hot it expands and grease leaks out between the cap and hub,,
boatnt is offline
