Myco wheel bearings
Old 06-11-2014 | 08:07 PM
Default Myco wheel bearings
Anybody know the part number/size?? I want to pick up a spare set or two before I head up north. You know how it works, If I have spares I wont need them,
phragle is offline
Old 06-11-2014 | 08:16 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Call them with your model number. They can sell you exactly what you need.
Sydwayz is offline
Old 06-11-2014 | 08:43 PM
Full Force's Avatar
what axles? I just did all mine, I might still have packing slip here... I have 5200lb 6 lug axles
Full Force is offline
Old 06-11-2014 | 08:46 PM
5 lug, drum brakes...was originally under a 24 cig if that means anything....
phragle is offline
Old 06-11-2014 | 08:50 PM
Full Force's Avatar
If they are Dexter (probably are) you should have the 3500lb axles they are standard, or just pull one apart and get numbers off the bearings in there, I was also told that the smaller ones may be same as a simple car like 80's GM front rotor, but not sure...lol
