Cutting Edge 22P 5 blade >
Old 06-13-2014 | 05:06 PM
Default Cutting Edge 22P 5 blade
Cutting Edge 22P 5 blade prop. 500.00 [email protected]
Itsallgood995 is offline
Old 06-14-2014 | 07:22 AM
What did you have this on? Would it make sense on a 23' Baja with a 6.2? I've always been curious to try a 4/5 blade...
jetskidrewski is offline
Old 06-18-2014 | 09:12 AM
Had it on my 'Four Winns H240 with a raised X. Not sure about your application but it was a great prop for watersports & the raised X.
Old 06-19-2014 | 08:11 AM
DId you compare it to anything else, 3 or 4-blade? I'm definitly interested, but am a little nervous to pull the trigger on an 'odd' prop.
Old 06-19-2014 | 11:00 AM
Yes I tried Mirage+, Rev 4, Hydro QIV & QIVX, Bravo 1 & a custom labbed Maximus that I had over 1100.00 into. This prop sold me on Cutting Edge props.
Old 06-19-2014 | 11:08 AM
opps
Old 06-24-2014 | 09:40 AM
ttt
Old 06-27-2014 | 02:10 PM
trade for Enertia ECO 23P
Old 06-27-2014 | 03:43 PM
Are you unhappy with the midrange of the cutting edge? Just curious why you would prefer an Eco.
Jonesy23 is offline
Old 06-28-2014 | 01:46 PM
I own the first two 5 blades bravo's they every made. Still using both props today. One that I damaged and they repaired has taken a beating over past five seasons as my "trash prop" used in shady water conditions. Runs within 1mph of the other, just higher revs.
You should see excellent out of the hole thru mid-range performance with probably a bit higher slip numbers on the top end because of the 5 blades drag.
If that was a 26P I'd be all over it.. I'm looking for a wake boarding prop, 10 less than my smokin 37P.
kidturbo is offline
