FAST Programmable EFI >
Old 06-17-2014 | 10:34 PM
Rookie's Avatar
Default FAST Programmable EFI
The last few weeks I have been playing around at the shop with the new FAST EZ EFI 2.0. I don't believe it can get any easier then this. It comes with a little tablet and you just need to answer a few questions.
This is a direct carb replacement. Everything comes with it, fuel pump, regulator, gauge, filter hoses and hardware. This is the 1200HP kit that has 8 injectors in it and will flow ~1050cfm. JimV (Valako) just installed a pair on a set of 540's he just built.
I think I might be going to EFI soon.
[ATTACH=CONFIG]524833[/ATTACH]
[ATTACH=CONFIG]524834[/ATTACH]
[ATTACH=CONFIG]524840[/ATTACH]
https://www.youtube.com/watch?v=njqqYyLhYJE&app=desktop
Attached Thumbnails FAST Programmable EFI-20140617_180342.jpg   FAST Programmable EFI-20140617_175908.jpg   FAST Programmable EFI-20140617_180214.jpg
Rookie is offline
Old 06-18-2014 | 06:44 AM
I've heard of guys using the FAST EFI on drag cars around here, never thought about a boat application. Sounds nice!!
Jonesyfxr is offline
Old 06-18-2014 | 08:18 AM
I think they require 02's and there may be the issue..
ezstriper is offline
Old 06-18-2014 | 09:55 AM
Rookie's Avatar
It has O2's installed. We actually ran it for 30 mins with the silent choice shut with no issues. I believe once you are satisfied with the automatic learning you can turn it off and it will use the last stored fuel, load, TPS etc data. I'm still just learning this. When Jim and I were at the PRI show I believe they spoke of this.
The cams are relatively mild making around 700HP.
Rookie is offline
Old 06-18-2014 | 03:46 PM
GPM
Keep the 02s dry and they will work for a long time.
GPM is offline
Old 06-19-2014 | 07:13 AM
that is easier said than done with some exhaust...
Old 06-19-2014 | 08:18 AM
28Eliminator's Avatar
It looks like a pretty nice setup. I have read other post about programming it and it seems like you give it some parameters and it self tunes. I can't really tell where the injectors are with your pictures. Are they in each intake runner or?
28Eliminator is offline
Old 06-19-2014 | 08:57 AM
they are in behind the covers that say fast.
sutphen 30 is offline
Old 06-19-2014 | 09:40 AM
donzi matt's Avatar
Is this a returnless fuel system? It looks like I see two inlets unless one is the feed and one is the return.
donzi matt is offline
Old 06-19-2014 | 09:59 AM
Rookie's Avatar
FAST put 4 injectors where the float bowls on a carburetor would be located. They are 4150 style flanges.
http://www.youtube.com/watch?v=MXiX3EBT9dE
They can be ran with return or return-less. They recommend with a return. This is also setup with the exterior fuel pump you can also get an in tank fuel pump.
Rookie is offline
