Switches for the Trim >
Old 06-19-2014 | 03:58 PM
Default Switches for the Trim
Just above the throttles on my 2002 353 there are switches for the Trim/Tabs/Trailer up. Has anyone found a source for these besides the factory that fit into the same hole that is already cut. Wouldn't mind a nicer looking switch anyways than the factory plain white ones.
My Starboard side trim switch only goes down, not up. When you press it you can tell the switch has an issue.
gsxrmike is offline
Old 06-20-2014 | 04:35 AM
axapowell's Avatar
Where To
It's not the switch, it's the switch cover. Formula can direct you to the vender, but they are not too expensive.
If you remove the cover, you will see a tab that controls the switch. It is broken or cracked! Temporary fix is to rob. One from the trailer switch!
Dave
axapowell is offline
