Cobra outdrive not pumping water >
Old 06-19-2014 | 07:23 PM
Default Cobra outdrive not pumping water
I have a 1988 liberator i just unwinterized it and the water pump is not working, i took the hoses off the waterneck and there is no water flowing . i'm running it on the ear muffs . i took off the pump housing and water is getting up to the pump. the impeller is not missing any pieces could it still be bad . thanks for any help
jbenzeleski is offline
Old 06-19-2014 | 07:34 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Yes it can still be bad . Look for any flat spots on the end of the vanes . They are very easy to change in those drives just make sure you lube up the new one on install . You may want to check your thermostat to make sure it's opening and free of rust .
the deep is offline
Old 06-19-2014 | 07:37 PM
yes it does have some flat spots and seems to have lost its stiffness it spins kind of easy .
Old 06-19-2014 | 07:39 PM
the deep's Avatar
Fast Singles Club
Yep needs replaced .
the deep is offline
Old 06-19-2014 | 11:17 PM
BUP
And the blades most likely folded over as well since it is very stiff. Make sure the little hose coming off the housing has a good fit as well. A lot times we use to put a small tie wrap around it.
BUP is offline
Old 06-20-2014 | 05:26 AM
the cobra is easier to change than the merc, but being higher it sometimes has a harder time priming. all the more reason to have a new impeller. seals to housing a lot better.
dereknkathy is offline
Old 06-20-2014 | 10:14 AM
I used to have a boat years ago wit twin cobra's, one I put in aftermarket pump kits and one would not pump...took back apart saw nothing...replaced with OEM worked great again, so the tolerance for the impellor/housing is critical...
ezstriper is offline
Old 06-20-2014 | 11:22 AM
BUP
Agree 100% about the tolerances of impellers and do not forget the housings as well especially if they a scared, that also can put your tolerances out of spec. Also with aftermarket impellers some will spin the hub done the road as the bonding agent can let go or deteriorate over time. Quality impellers are very important. and good sealing of the impeller housing as well.
BUP is offline
Old 06-20-2014 | 11:32 AM
mym housing has no vent hose coming off it .
Old 06-20-2014 | 12:12 PM
BUP
Ok you must have the 7.4 L or the 7.5 L engine was thinking maybe 5.7 as it is very hard to guess what people have without all the info and model / serial #'s.
BUP is offline
