New Unused Superflow SF 901 Dynometer
Dyno Features:
• Superflow 871 water brake absorber unit
• 8- Type K EGT Probes
• 400 lb/hr fuel flow turbine
• Holley fuel system with fuel regulators
• CT 600 thermostatic control cooling tower
• Vacuum/pressure port
• Water temp in/out transducers
• Oil temp in /out transducers
• BSFC ( brake specific fuel consumption ) data
• BSAC ( brake specific air consumption ) data
• Air fuel ratio
• Volumetric efficiency
• Oil pressure sender
• Fuel temp. reading
• Inlet air temperature
• 1 1/8” x 26 spline input shaft
• Innovation engineering aluminum drive plate
• 4500 air turbine ( for Holley Dominator carb)
• Windyn Data acquisition
• Operator console with load control
• Barometric pressure transducer
• Dual built in battery trays
• Stainless drip tray
Additional Dyno cell Equipment included
2- industrial grade mufflers w/ elbows and pipe connections ( new)
2- 925 gallon polyurethane water supply tanks (new)
2- 7 HP supply and return water pumps
2- industrial exhaust fans ( new)
Dyno and equipment have literally never been hooked up for use!
$35,000 Ask for Dean: 440-476-3558
• Air fuel ratio
