Running temp on your 6.2
Quick question for the peeps running a 6.2 mpi. What is your cruising temp? I have a repower with 6 hours on it, new sea water pump and thermostat...it operates at 150 and will climb and stay around 175 when I run 3-4k rpm. Once I idle back down it drops and stays 150. I believe it has a 160 thermo in it. Is this normal or should I look for obstructions? Also, if I feel the exhaust elbow sometimes it is kinda hot and sometimes it is cool as can be. But the temp gauge never rises above 175.
Thanks and Happy 4th!
