Need VDO Temp Sender
My local guy is having a problem finding water temp senders for my VDO gauges. (100-220 degrees) Anyone got a source?
And before anyone says anything, yes, I am planning on redoing the entire dash with new gauges.
Thanks!
Thanks!
Wow. Funny I was just going to post a problem with my vdo temp gauge. Maybe you can tell m if the sender is the problem. My gauge works very sparatic. I tried the grounding technique and gauge seemed fine. Connected it and it worked for a minute and stopped. It happens over and over. I got my sender from ft lauderdale. Florida
The way I could tell (at first) that it was the sender is I looked at the engine data from the laptop, showed 20+ degree difference between what the engine saw and what the gauge said. Next time out, the gauge showed 160 degrees at START UP. It starts there and just goes up.
