Prop slip calculator >
Old 07-05-2014 | 08:31 PM
Tinkerer's Avatar
Default Prop slip calculator
What is the numeric number to use for 1.36 to 1 gear ratio?
I am trying to find what my slip numbers were today.
Tinkerer is offline
Old 07-05-2014 | 09:00 PM
Tinkerer's Avatar
figured it out.
Tinkerer is offline
Old 07-06-2014 | 12:52 AM
http://www.mercuryracing.com/propell...calculator.php
Supreboat in is offline
Old 07-06-2014 | 04:50 AM
Rookie's Avatar
There's an App for that.
[ATTACH=CONFIG]525698[/ATTACH]
Rookie is offline
Old 07-06-2014 | 09:31 AM
Tinkerer's Avatar
I found all kinds of slip calculators just didn't realize that I was just supposed to enter the 1.36 ratio.
how does 11 percent slip sound with a 4 blade Bravo prop and a prop shaft height 7/8 above the lowest point of the hull?
Tinkerer is offline
Old 07-06-2014 | 09:57 AM
11 % is not bad at all. IMO but that's just me
abones is offline
Old 07-06-2014 | 11:16 AM
I got 28% wtf?
KRAUSMOTORSPORTS is offline
Old 07-06-2014 | 03:51 PM
Tinkerer's Avatar
when I put the 26 maximus on I was at 8%
Bret from BBlades said that is race boat efficiency - BUT it didn't handle properly with the stock prop.
Tinkerer is offline
Old 07-06-2014 | 04:52 PM
So what is the proper percentage range that you should be in? I calculated mine and I was at 20%. I am running XR drives with imco shorties and 34 five blades.
98Fever27 is offline
Old 07-06-2014 | 05:15 PM
Tinkerer's Avatar
I believe15 to 18% is normal for a V bottom.
Tinkerer is offline
