Go Back  Offshoreonly.com > Owners Forum > Phantom
What props work best on a 34 ? >
Old 07-06-2014 | 12:57 PM
Default What props work best on a 34 ?
Bravo. Hydro, 4 or 5 blade. I have a set of imco 1 in shortys I want to put on and im not sure what prop works best. Even if the 1 inch is to much ill put in a spacer . I think the imco designed lower should be faster than a standard bravo style plus they are large shaft.
Velocity Tom is offline
Old 07-06-2014 | 02:26 PM
bwd
Erase some msgs. or call me at 978 479 3636
Brian
bwd is offline
Old 07-06-2014 | 02:36 PM
Sorry didn't know it was full. Send away!!
Old 09-03-2014 | 09:23 PM
BronxPhantom106's Avatar
i used a set of 30 6 blades boat road amazing have 2inch shorties with its boxes on mine with hp 500 boat did 92 cruise speed at 4000 rpm is 70
28ft Armada BatBoat, 34 phantom, 24 euro warlock, world fastest 40ss formula, 30ft activator one of a kind...... never enough toys
BronxPhantom106 is offline
Old 09-04-2014 | 04:24 PM
Im running a high x from the factory and 1 in imco shortys and my engines make 509 at 5100 rpm. . With stock out of the box 34 4 blade bravo,s I run 90.3 At 4800 rpms on a 90 deg. day in a 1 ft chop. I Just got my props back from BBlades and I havent had time to try them yet.
Old 10-09-2014 | 03:07 AM
How did your new props work out ?
Smarty is offline
Old 10-09-2014 | 04:49 PM
90mph at 5k rpms. going to send them back and have them loosend up a bit.
Old 10-10-2014 | 12:31 PM
Understood
Smarty is offline
