704ci Motor Help >
704ci Motor Help
704ci Motor Help
Old 07-07-2014 | 09:50 PM
Default 704ci Motor Help
Just got a 42' Fountain/ Scism Cat from Randy at fasboats.com and brought it to the Lake of the Ozarks, MO. Boat ran good there is just oil coming from the K&N valve cover breathers on both engines. They are 704ci Dart Blocks with Brodix heads. Anyone have any suggestions on what to do to stop it?
bdecker is offline
Old 07-07-2014 | 09:59 PM
How much thats the question. Blow by is normal within reason. If its no to bad you can run a hose up to the flame arrester. If motors are dry sump pipe breathers back to dry sump tank, then breather from top of dry sump tank out back of boat by tailpipes.
43sv is offline
Old 07-07-2014 | 10:05 PM
Thank you, It does appear to be quite a bit. It is running down the side of the motors to the transom. It probably looks like way more than it really is but there is quite a bit of oil. Everything else appears clean. Im not sure if they are dry sump or not. I'll have to find out. Im still in the learning phase Thanks for the info!
bdecker is offline
Old 07-08-2014 | 05:10 AM
you don't know if dry sump or not. where do you check the oil? there are some things you just hafta know...
dereknkathy is offline
Old 07-08-2014 | 06:22 AM
HEDGEHOGER is offline
Old 07-08-2014 | 06:54 AM
Keep the rpm's below 5000, dry sump them or clean up oil.
brian41 is offline
Old 07-08-2014 | 07:15 AM
Sorry dereknkathy, like I said still learning. The oil is checked with a dipstick that goes through the oil pan. Below is the link to when it was listed.
http://boatspotter.com/Page.aspx/dii...ain-Scism.aspx
bdecker is offline
Old 07-08-2014 | 07:25 AM
the simplest solution would be breather baffles, somthing like this http://www.summitracing.com/parts/mr...-jxxoCX6vw_wcB If that does not work then catch can breathers work will but you have to drain them periodicaly http://www.summitracing.com/parts/ct...8_sBoCZ-rw_wcB
professor_speed is offline
Old 07-08-2014 | 07:28 AM
TomFTM's Avatar
you can try putting an extension on the kn getting it higher further away from the valve cover which might help, or you can put puke tanks in . a hose off each valve cover that goes to a tank with a vent ..
TomFTM is offline
Old 07-08-2014 | 08:22 AM
SB
WOW !!! Boat looks great. Hope you enjoy.
Sorry for sidetrack to subject in thread.
SB is offline
