Pair of 775HP 540 CI Blown/intercooled and fuel injected motors
I'm parting my boat out after a trailer mishap. Can be heard running in the boat.
A conservative 775HP each. Motors have 220 and 230 hrs. Valve springs done at 150 hrs. The timing belts were done 3 hours ago along with the sea pumps. These motors were religously maintained. Have pre-lubers. so never a dry start. Most of the hours have been below 3000 rpm. It pushed a heavy 36' foot boat to 90 MPH on GPS, turning 31P 18" 4 blade props to SSM3.
-GM Siamese tall decks 540 CI
-Callies cranks, Carrillo rods, JE pistons
- Crane Hydraulic roller cams
-Aluminum Dart heads
-Jesel timing belt assemblies
- Brodix intakes with fuel rails, HAWK throttle body and 72lbs injectors
-Electromotive Fuel Injection and Ignition. Distributorless and fully programmable setup. Have the software, so you can datalog as well. Can change pullies and get more power if desired
-Vortec V4 race blowers with Procharger intercoolers.
-KE 2 piece valve covers
-High torque mini starters
-Gill manifolds and custom riser
-Stewart water pump
-Aeromotive adjustable fuel regulators
-Aeromotive A1000 fuel pumps.
I have receipts for most of this as well. Motors were balanced and blue printed.
These were closed cool since new, so no internal corrosion. Always ran at 160F. Have KE oil thermostats as well.
$33k Turn key for both or $17K each
Serious inquiries only
[email protected]
Located near upstate NY.
-Stewart water pump
[email protected]
