Go Back  Offshoreonly.com > Boat Club Forums > Northern Illinois Offshore Club
NIOC Thunder Run Slip Information - need you to reply >
Old 07-08-2014 | 03:01 PM
rv
Default NIOC Thunder Run Slip Information - need you to reply
If you are not getting a slip for for the Thunder run ignore this.
For those getting a slip please send email with the following information by 7/10 to:
[email protected]
There has been damage to some docks in the marina so the docks we planned on using have less open slips. We will accommidate everyone but if you don't need shore power or you have adapter plugs for higher current/voltage we want to know so we can match everyone to slip requirements.
1. Your name
2. Cell phone #
3. Boat Length / boat name
2. Do you require shore power, if yes can you plug into higher current/voltage supplies
a. 50A/120V
b. 50A/208V
We will comply this information and provide to the marina so when you call to reserve slip they aleady have it assigned and your check-in will go quickly.
Starting Sunday 7/13 you can call the marina at 847-746-2845 to get your reservation and they will process your slip assignment. Once you arrive at the marina stop at the admin building to pickup your paperwork for the slip. You will need this to park you vehicle/trailer and boat in the slip. The admin building is directly in front of you when entering marina and at stop sign to turn left to go to boat ramp.
Rick
847-502-2399
rv is offline
