Installing water pressure gauge >
Old 07-10-2014 | 09:24 AM
Default Installing water pressure gauge
Looking at installing water pressure gauge on 502. Where is the correct (best) place on engine to install sending unit?
Satisfaction is offline
Old 07-10-2014 | 10:58 AM
Mine our on the intake manifold so they don't get plugged with sand or dirt. Do a search you will find several posts on the subject.
1BIGJIM is offline
Old 07-10-2014 | 11:52 PM
I have mine in the intake manifold as well. Using the block drains will clog up with sand.
Revd Up is offline
Old 07-11-2014 | 12:55 AM
What they said.
Griff is offline
Old 07-11-2014 | 06:15 AM
Thanks, that's what i was thinking.
what is the ideal water pressure for lightly modified 502 with bravo?
Old 07-11-2014 | 09:33 AM
Search Function returned 4 pages for your reading pleasure.
1BIGJIM is offline
Old 07-11-2014 | 07:21 PM
Mine was factory located on the oil cooler h2o drain (Fountain).
Wes Burmark is offline
Old 07-11-2014 | 08:21 PM
SB
I like that place.
Merc suggested to place their water pressure regulator (available thru any Merc dealer if it's needed) after oil cooler and before engine inlet.
SB is offline
