EGT ranges procharged carb 555
M3sc with 504 inter cooler. Egt probe in riser on gil exhaust. Carb box setup. Iron heads, 8:1 comp.
Where should my operating range be to and from? 800-1400??? Just curious
with the sensor mounted in your riser i would not let it go over 1200*..what happens in the cylinder is not happening that far up in the riser
When we ran an EGT setup on our drag race car "back in the day", the sensor was supposed to be mounted 2" away from the header flange. I don't think it being in the riser is going to be usuable to tune with at all.
Wideband O2 is where its at
I believe EGT's are a reference only tool. When you have a known good tune note the EGT temps. If they change at some point you might have a problem. I know some tunes that are around 1450°F, but as stated earlier probe placement has a lot to do with it.
