350mpi overheating??
Old 07-13-2014 | 01:12 PM
Default 350mpi overheating??
noticed that my starbored engine 350mpi bravo 1 drive was heating upto 175degrees alot faster than my port engine. however after cruising for about 10-15min the port engine eventually catches upto the other?? i thought maybe i had sucked up some debris in that drive but flushed both units several times and it still seems to heat up alot fater than the other. not sure what to do next, disconnect engine hoses and check for additional debris?? i did churn up some sand a few weekends ago but had a 40min ride home afterwards i would have thought it would have cleaned most of it out?? not sure any thoughts??
mmr1229 is offline
Old 07-13-2014 | 01:24 PM
It could be that the engine that's taking longer to heat up has a thermostat that is stuck slightly open.
abmotorman is offline
Old 07-13-2014 | 01:31 PM
interesting, so for the motor to warm up to 175 degrees in about 5 min is no problem? and is 175 too warm?
additionally, when i flushed both systems they both seemed identical in terms of water flow.
mmr1229 is offline
Old 07-13-2014 | 01:49 PM
bravoitis... first place to ck is the feed hose at the transom ..save alot of time and ck that first .then move on to sea pump ect
smokin' gun is offline
Old 07-13-2014 | 04:07 PM
i apologize but can you elaborate... i assume you're speaking of the hose that connects from the water pump to the transom assembly??
sounds like this is a common problem with the bravo drives??
mmr1229 is offline
Old 07-13-2014 | 04:16 PM
yes it is extremly common ..it doesnt have to be a salt water boat either ..ive fixed so many i cant count em .i make it common practice to ck them every time im working on a transom or have an engine out
Old 07-13-2014 | 04:27 PM
ouch! so... i have to pull the motor? im new to the performance boat set up, sorry.
mmr1229 is offline
Old 07-13-2014 | 04:45 PM
motor dont have to come out to ck it. 2 bolts hold the adapter on that the hose connects too at transom .you will need 7/16 wrench.. under that adapter you should be able to stick your finger in the hose thats there ..corrosion builds up around the outside of the hose and shrinks it down to nothing ..ive seen more guys remove thermostats replace impellers and circ pumps only to find its the supply hose that wont pass water
Old 07-13-2014 | 05:56 PM
thanks so much... will definitely check it out.
mmr1229 is offline
Old 07-15-2014 | 08:01 PM
Are you flushing them using installed flush outs or using muffs? If you are using muffs and are still getting good flow then the pick up tube is not your problem.
RGPIII is offline
