Pressure test headers question
I bought a 4" plumbing plug that has the rubber stopper and the wing nut. You have to crank it down pretty hard but it stays in there. Then take a flat piece of 3/8" flat stock and drill it with a header gasket, add a schraeder valve, and air it up.
Hook up water hose to bottom water inlet. Fill with water until it is just about to come out of the top water outlet. cap the top water jumper outlet with 1" rubber cap and hoseclamp. Most homes have water pressure of 40-70psi which is higher than your boat will run. Turn on water and look for water coming back down the runners. This is the only failsafe way to test them and also the easiest...air pressure tests can be very difficult and inaccurate.
its a lot simpler to use pressurized water for most people than to fabricate a steel plate and insure that it is sealed well, drill and tap for a shraeder valve. You can easily get a false reading that your headers are leaking when in reality you don't have them sealed well enough. How are you going to know the difference???
There is a reason that most top engine builders use water pressure to test them rather than air. I am not saying it can't be done, just a LOT more work and not foolproof.
