502 fuel injected spudders and dies  randomly >
Old 07-14-2014 | 01:53 PM
Default 502 fuel injected spudders and dies randomly
I have a fuel injected 502 magnum that randomly starts to spudder and cut out then die mostly happens at idle but has also happened one time at wot then I turn the key off and start it back up and is fine for awhile I am also only able to get 4000 max rpms out of it I have changed plugs ,wires, cap , rotor and coil I ran some fuel additive through it for the first tank because it had sent been ran for 2 years but now I have rsn 2 tanks through it and still doing it. Any info is appreciated thanks
Bauer939 is offline
Old 07-14-2014 | 02:05 PM
Fuel filters may be gummed up from the old gas sitting and now being run, the nasty stuff may have went from the tank to the filter.
Going to want to check fuel pressure as well...but I would be changing the fuel filters first.
TooLateVTEC is offline
Old 07-14-2014 | 02:11 PM
I have changed the fuel filter twice already this summer did a compeesion test that was good and cleaned the filter in the bowl that's on top of the motor I was told that's were the fuel gets presherized to go to the injectors
Bauer939 is offline
Old 07-14-2014 | 02:54 PM
Check your kill switch. Overtime the plastic parts on the lanyard end loosens up enough to cause the engine to cut out or quit. I have had this happen on two boats.
Padraig
Padraig is offline
Old 07-14-2014 | 06:39 PM
Pull, clean and flow test all your injectors.
Trash is offline
Old 07-14-2014 | 07:09 PM
F-2 Speedy's Avatar
Lets start by telling us what you have, year, VST or cool fuel, I presume its a 502 MPI mag ?
F-2 Speedy is offline
Old 07-14-2014 | 09:07 PM
+1... plus replace you idle air control valve
kevinb230 is offline
Old 07-15-2014 | 09:18 AM
It's a 502 mag fuel injected w/cross ram induction system I believe the motor is a 92 because that's what year the boat is and I was told he had the factory put it in . Idk if it vst or cool fuel
Bauer939 is offline
Old 07-15-2014 | 02:58 PM
Check out the fuel rails for a shrader valve where you can check fuel pressure.
Removing and having the injectors cleaned and flowed is a good idea, especially if you dont know the last time its been done.
Old 07-15-2014 | 03:07 PM
Check the anti-siphon valve too
johnny b good is offline
