Replacing MEFI1 with ?
Considering replacing my MEFI 1 computer on my Procharged 502 mag. I would like to keep my stock intake and am in the process of upgrading my injectors. Anyone out there done the same thing and how did it work out for you?
At this point I am cosidering the Holley EFI set-up. I believe it will plug into my stock connectors? Any other systems out there I should look at?
Thanks!
Thanks!
I have had great luck running an O2 sensor in the collector of my Lightning Header
I installed the Holley HP on my Harley Sport Fish about 18 months ago (502s Aluminum heads, stainless marine manifold, short risers, Marine Kenetics cam) At first, port motor was eating o2 sensors every 15 hours. Alex Haxby suggested that I retard the timing in the idle area to raise the idle EGT. So far so good. I think I have about 35 hours on the current sensor with no issues. Starboard engine has never ruined a o2 sensor with 100 hours total time.
Overall I am very happy with Holley HP. Relative easy to tune for a rookie like me, and Alex Haxby can guide you quickly through any issues.
I used the MEFI Burn software previously, and it wasn't for me. I didn't have the patience for it. Just too clunky for me to use. I'm sure there are many here that would be successful with it. Just not me.
I am running the alloy Keith Eikert headers with dry tailpipes and the bung is a good 18" away from any water, but the boat is kept in the water all the time in a marina and I think corrosion from the salt atmosphere is my problem. I am just about to fit my third O2 sensor in [the boat has been on its mooring for a year]. With this one I am thinking of unscrewing the sensor while I am away from the boat to see if that helps.
http://www.innovatemotorsports.com/x...8&cat=0&page=1
