thru hull exhaust melt down?
Chevy 350 with thru hull exhaust. Somehow managed to burn up the rubber hose, internal flapper, and external rubber flapper on one side of the motor.
http://www.offshoreonly.com/gallery/...19639&cat=3071
Any idea(s) how this could happen? I'm thinking I must have lost water, but when I smelled the burning rubber I stopped the boat and opened the hatch while idling and I could keep my hands on the exhaust risers. Temp gage never went up either. Started the boat up the next day and water was gushing out at idle. All the rubber from the internal flapper turned to a complete molten state and is now spattered on my transom.
Poppet/check valves in the thermostat tee? Can I take them out?
Thanks!
Thanks!
I'd pull all the cooling lines you can and back flush with air and water. You may have ingested some debris, OR perhaps debris covered the water intake for a period of time then self extracted. Plastic bags floating in or just under the surface can be an issue at times.
I have had that issue in the past, so it does happen! Expensive lesson I learned from other peoples trash!
The lake has had a lot of clumpy weeds/scum piles near syrface. Glad I sat down and got behind the windshield and got a whiff of the burning rubber. Otherwise I'd kept on running it and probably started a fire.
Or another thing is a loose belt on the seawater pump. Could have some grip at idle but slips at higher rpms and giving you water through the system.
-Wally
-Wally
