Engine won't rev over 2800 RPM while in gear -- Need some tips >
Old 07-17-2014 | 11:22 PM
Default Engine won't rev over 2800 RPM while in gear -- Need some tips
My star engine won't rev over 2600 rpm while in gear, but my port side works just fine.
557 engine with 750 Holley/8-71 blower/Accel Ignition box
So far, checked
Coil, rotor, cap, wires,ignition box, engine oil level, fuel filter,fuel pump,distributor, gaskets ( found out blown intake gasket) ,no blockage on the exhaust, compression are around 120 overall. what is next?
steven0720 is offline
Old 07-17-2014 | 11:28 PM
Ign timing/advance?? Throttle linkage??
zz28zz is offline
Old 07-17-2014 | 11:46 PM
check the shaft on the blower snout,if the splines hava a lot of ware they might not be engaged very good,i have seen it happen before.
mike tkach is offline
Old 07-18-2014 | 06:39 PM
Did the timing light today, 27 idle and 30 when in gear around 2100 rpm. However, the back firing poping noise is happening during the no loaded as well.
Old 07-21-2014 | 07:58 AM
Have you checked fuel pressure/volume? Could it be sucking the bowls dry?
Jon01 is offline
