Been wanting to try a 21p prop for my 232 islander...found one maybe..questions
I found a guy who has a Michigan wheel 21pitch Stainless for sale for $120. It came off of a Alpha 1. This would work on my Bravo 1 correct? Also, it looks like it is a solid hub, should I only stick with rubber? I currently have the Mirage + 19 pitch on my boat (6.2). What is the big difference between the Mirage + and Michigan stainless? Sorry for the questions, just trying to get some info to see if it is even worth trying this prop out and spending $120.
Thanks,
-Abs
Thanks,
-Abs
We don't carry Mich wheel props but there are some basic things to look at. First, if it was on a ALpha it will work on your Bravo.
What is the diameter of the propeller and how does it compare to your Mirage+?
Can you try it or do you have to buy it? If you can try it, do.
Brett
Brett
[email protected]
[email protected]
