Time to replace spark plugs
Here is a nice cross chart. I use delco now, was using NGK
http://www.dragstuff.com/techarticle...reference.html
If you choose to use NGK make sure you buy them from a reputable source. If you search for the best price on-line and they are from a not well known source, you can very well end up with black market copies that look exactly like the originals, even the box is a near dead on copy. The market has been flooded with these Chinese knock-offs.
I know with a car I replace based on miles
what are some of the performance issues with a boat that would indicate that the plugs needs to get changed out
I know this is a dumb question - but I'm really new to this mechanical stuff --
3pointstar
3pointstar
It really depends I guess. IMO a high performance boat should get new cap, rotor, and plugs every two years.....wires every 4. Boats run a higher average EGT than a car, are stored for long periods, and are in a harsh environment all the time.
I must be over the top.. I do it every year lol.. That was with my 600SC though. I will probably do every 2 with the 502's in the new boat
Wires: 10+yrs on stock black motors.
Regular plugs - every 2-4yrs. Same with cap/rotor. Black motors again.
Platinum/Iridium - when you feel like it. 5+ yrs probably a good time to replace.
Above on fresh water and usually covered boats.
High performance engines - before they get used up. LOL.
I was using mr41t which is stock. This year I tried 42ts because I was fouling down low, but it turned out to be a fault map sensor on one that was intermitten. I am going back to the mr41t this week
