Serpentine to v-belt >
Old 07-23-2014 | 10:05 PM
SBX
Default Serpentine to v-belt
Currently have a gen vi 502 with serpentine setup.
Purchased a 177 blower off a 525sc
Looks like I will need to convert to v belt? Or can I keep the serpentine setup?
SBX is offline
Old 07-23-2014 | 10:39 PM
You can keep the serpentine setup. You will need to change you crank pulley to something that will accept a blower pulley. We use this one:
http://www.cpperformance.com/p-14619...ock-chevy.aspx
You may or may not need a spacer to get proper supercharger belt alignment. This pulley has 6 threaded holes in it so that you can bolt up a supercharger pulley of your choice to it.
Hope this helps,
Eddie
Young Performance is offline
Old 07-23-2014 | 10:44 PM
SBX
Yeah that would be simple. And a cleaner look than the v belts.
Not cheap lol. But a simple solution for sure. Thanks!
SBX is offline
Old 08-08-2014 | 04:42 PM
SBX
Eddie, I called CP about this pulley and frankly they were of very little help telling me it was set up for a 500efi and would not fit my engine.
So with that said I have my stock pulley and it seems too deep also the billet cylinder will not fit inside it to center the blower pulley.
I am assuming that this pulley you referenced will allow the blower pulley to seat and I will need to use some spacer behind this pulley?? If you or anyone can offer any solid help I would be thankful...looking to assemble the engine this coming week and bolt the blower on, I would like to handle this pulley situation monday.
Other option I guess is go v belt, I have a v belt pulley for the crank, alt and water pump, but I need to round up a power steering and sea pump one I would guess.
Scott
SBX is offline
Old 08-08-2014 | 05:30 PM
SBX
Will this blower pulley from weiand work?
SBX is offline
